I'm not saying whoever said "its all in the cam" was a liar, but he obviously wasn't going to give away all his secrets. If it were just cam, every garage engine "puter togetherer" (not builder) could produce the same power as the professional engine builders who have been researching how to improve the A engine for 20+ years. Yes cam change does help a lot. But that doesn't necessarily get more air in and out faster. You need some major porting done in the valves, along with bigger SS valves. and even with most high compression heads if you plan on running more than normal rpms could use some porting. More carb, because if you go with a pretty big cam change a zenith won't cut it. If you want the power all the time I suggest a stromberg instead of a weber. Both work fine, I just like the strombergs better because their 2 barrel all the time. You also need to think about getting the exhaust out. Reds tube headers are probably the best bang for your buck as far as headers go. Then a Aries muffler that Is less restrictive.
My brother has the 3/4 race cam in his 4 door. Great cam in my opinion. No it doesn't sound like a model a at idle, but it runs really really well down the road, and even pulls overdrive really good. I put the windfield race cam in mine. Personally I like it. It doesn't like anything below 800-1000 rpm. But will run like a scalded dog when you give it the juice. But, this cam doesn't seem to really wake up until around 1800 or so rpm. 2000+ is when it just starts to get fun. That being said, it doesn't pull overdrive that well. Flat land it's great, but a hill you can feel it die off. I'm probably going to switch to 16's to gear it down little so hopefully it pulls overdrive better. Plus I like the looks of 16's better.
You can double a flat heads horse power relatively easily as long as your machinist knows what he's doing. After you get past about 110 hp you're not going to have a long lasting road motor, so it's best for a long term driver to keep your goal under 90-100hp. Which is more than what most people would want out of their "stock" A anyways. If you're wanting a "hopped up" motor my personal suggestion would be just a snyders head, inserted and balanced bottom end, 3/4 race or less cam, SS valve set, extensive valve porting, carboration, and exhaust. And I bet you'd be grinning from ear to ear everytime you pulled hill, or left a red light.
