Skibb Well-known member Mar 17, 2015 #1 Is all replacement glass the same spec or are there differences. That's a dumb question but I don't know.
Tom Wesenberg Well-known member Mar 17, 2015 #2 If you mean the thickness of the glass, then the answer is yes, it can vary.
Bob Bidonde Well-known member Mar 18, 2015 #4 Modern safety glass is thinner than the original plate glass. However, modern safety glass has a consistent thickness because it is made to a common SAE specification.
