GL4 or GL5
Rance29
I am looking for the proper gear lube for a 1934-5 one and a half ton truck 4 speed transmission. It doesn't have synchros. I have been told I have to use GL4 gear lube but it's have proven difficult to find. Can I use GL5 in this trans or are there outer "yellow metals" in it that would be damaged by GL5?
NO synchros = no brass so you can use GL5 in it if you want. The 4 has a weaker additive that doesn't harm brass like the 5 will. For the cars 5 in the rear end 4 in the trans. That is my undedrstanding.
