dude Senior Member May 31, 2011 #1 221 V-8, Engine runs fine until you come to a stop. RPM drop to 400 then goes back to 800. I would think float level, reset lower and higher ,no change, Any ideas from you guys?? Thank you
FlatheadTed Well-known member May 31, 2011 #2 Is the engine moving working the gas pedal on its own .Ted
dude Senior Member May 31, 2011 #3 No. linkage is at dead stop at carb,if there was movment in the linkage, it would speed up.
