Jack as high as the jack will go and set your stands. Now lower the jack and put a 4x4 block on the pad and jack it higher. Repeat until it is where you need it.
I have read posts that say, "don't jack on the axles", and others that say, "it's okay to jack on the axles". I jack my '46 coupe on both axles, with a wood pad on the cup of a 3 1/2T capacity scissor jack. So far, no issues.
I've never heard not to jack on the axles. I've been jacking from the front and rear axles for years and never had an issue. I prefer to put the jack stands under the axles too unless I'm working on something that requires them to hang.
I ponied up for a pair of Quickjacks. https://www.fordbarn.com/forum/showthread.php?t=256084
Lots of video on YouTube, I bought the 12 volt model so I can use them anywhere. Beware once you buy a set you’ll have more relatives than you knew you had.
I saw this unit years ago, in an old garage on a trip through ND. I thought it would be nice to have, but would take up a lot of storage area compared to my scissor jack. Any idea who the manufacturer was? And before anyone asks, keep in mind I'm old, and CRAFT has set in, so I don't remember the place I saw it.
jack as high as the jack will go and set your stands. Now lower the jack and put a 4x4 block on the pad and jack it higher. Repeat until it is where you need it.
When wood was cheap, the deal was to make square rigging/blocking out of alternately stacked 2X4's. This would be a fairly pricey proposition since one 8 ft. piece makes you one layer cut at 2ft. lengths for one wheel. Last time I check, 2X4's were almost $10 per.
The rigging/blocking would go under the tires. Only limit was how many 2X4's you had.
