1931 flamingo Well-known member Jul 20, 2024 #1 This is the 2nd Genesis I've had that won't switch to 6V. About 2 years old and used about 3 times. Any thoughts? Paul in CT
Tinbasher Well-known member Jul 20, 2024 #3 I had the same problem. I found I didn't hold the button down long enough for it to switch over. (almost 30 seconds). Give it a try.
M mcgarrett Well-known member Jul 20, 2024 #4 Sounds like it's time to make an Exodus from the Genesis!
1931 flamingo Well-known member Jul 20, 2024 #5 I believe it's the genius. I have held it longer than 3 sec. Paul in CT
F flaw'd Junior Member Jul 21, 2024 #6 Mine works great. As stated, hold down for longer than three seconds. You can also recheck with a volt meter to verify.
