Genereator i.d.
Big Al
Hi,
i have several generators that i weould someone to identify.
The samping on them are:
Ford y-1
ford c-1
ford c-12
ford q-c1
some have a thick aluminum end on the bendix end
some have thin aluminum ends on the brush end
some have steel ends
and mixtures of steel, and aluminum.
Which are correct for a 41. Thank you.
Big al
Ok al, start all over!
First off i ment starter, not generator
no wonder one can't find the bendix on a generator
the "ford" stampings on the frame next to the numbers,
v-1 c-1 c-12 q-c1 to me, they look like model numbers
all of the information is correct (i hope)
i apologies for the confusion.
Big al
The starter for a 41 will seem like it is "faling apart" until it is bolted in, the 2 bolts that hold it together will also mount it the the pan ---I think that some starters after the flathead era had an oval plate that had "ford" and sdome other markings, but most flathead starters had few if any markings ---rebuilders would add their markings and codes.
If you want the starters you have IDed you will have a better chance with pictures, we know by shape, not by #.
Other than odd ball starters for later Mer-O Matic/Ford-O-Matic transmissions and 6-cylinder engines, the V8 starters are nearly all interchangeable. The early type had the heavier aluminum bearing housing and later ones had a thin bearing housing. Brush plates for 21A & later are all the same.
Regarding the date codes V-1 is Jan of 1941. the front plate for 41 should be the thick style about 1" and the rear plate for the brushes has 8 reinforcement ribs on the outside.
