peewee2you
Okay fellas, here is my plight I attempted to put my generator belt on today and had quite a tussle, I am trying not to scratch everything up, and am challenged so lifting the generator is one of my problems, but I have a nice engine hoist that I use to help get it in place and lower it down and thighten it up. I loosend the nut that holds the generator bracket to the block, and slid the generator down all the way to give room for the belt to slip up over the top, but it is not low enough to slip the belt over the pulley, it needs to under the crank pulley and around the two waterpumps and on the generator pulley. Any ideas on how I can get this belt back on without killing myself and scratchingeverything up.
I loosened the generator quite a bit and tried to tip in down in the front and slip the belt over the top to no avail, whew I was gettn' frustrated.
I believe the belt is the right one, it's the one that was on it when I took it apart, and one is on, would adjust okay, it's just an initial tight fit.
Is there any trick to this, or I just need another pair of hands with some good strength.
