I've just started my '30 tudor after years of restoration and I've driven it just a couple miles. During that time, I noticed that the ammeter shows no charge when the engine is running well above an idle. It will show a discharge of 8-10 amps when I turn the headlights on, so I'm confident the ammeter is working well. After a good 5-10 minute drive, I noticed that the generator was extremely hot to the touch. Also, when I attempted to polarize the generator (jumper the two contacts of the cut-out and see a small spark, per Tom W.), I get a substantial spark like a dead short. The cut-out is a new unit from Bratton's with the diode installed, and the generator is a fresh rebuild from a reputable shop that has done several before, and I've always been satisfied with their work.
The only thing I haven't tried is to install another cut-out that I have on another "A" that I know is fine.
Any other ideas before I pull the generator and have the rebuilder check it out? Thanks
