Generator issues
Chris Edgerton
Is it OK to disconnect one of the battery leads while the engine is running to see if the generator is working. My cheap ammeter isn't giving me a reading. My thoughts are if the engine continues to run that the generator is working. Please advise and Thanks, Chris
Assuming you car was wired correctly and the ammeter was working in the past turn on the lights and see if the ammeter goes negative, if it doesn't start by replacing the ammeter.
Charlie Stephens
The generator can put out up to 40 volts if the battery is disconnected and you don't have a voltage regulator on the generator.
If you let the engine idle at 550 RPM or less then you could briefly disconnect the battery cable, but don't turn on any lights, don't rev the engine, and don't do it for more than 10 seconds.
You can just connect a volt meter to the generator output stud and see if you get more than battery voltage with the engine running. Another way to check with no tools needed is to run the engine at fast idle and shine the lights on the garage wall at night. Then leave the lights on and turn off the engine. If the lights dim slightly, then the generator was charging.
Use an analog volt meter.
