I've tried to check the archives. There is a lot of discussion on this subject, but I haven't found an answer to my question. I'm going with 12v on my '41 pickup project. I have purchased the 12v field coils and installed them in the generator case. I've set up a test stand using an old motor set up next to an intake manifold.
To test it, I put a voltmeter on the armature terminal and spin the generator. I believe I should see a small positive voltage and then I should be able to touch the field to the armature terminal and see the voltage increase. The problem is I'm getting either no voltage or a negative voltage. I believe it must have to do with polarity of the fields. I'm thinking either the field coils or pole pieces need to be switched around. If I take the armature out, I find that with the residual magnetism, the south pole points towards the field terminal side. If I apply current to the fields, the polarity switches around. When I remove the current it goes back to the original state. I'd think the polarity should run the same direction in both cases, but don't know which way it should be. Can someone tell me how to get this working?
Thanks,
Larry Young
Thanks,
Larry Young
