To add a little explanation why the adjustment does what it does. The middle brush picks up electricity that electrifies the outside still standing coils, creating an electromagnet, that generates even more electricity inside the rotating coils.
By adjusting that pickup to the middle, you lower the voltage of the still standing coils, making them weaker magnets, lowering the overall output of the generator.
If you turn it to the right it will pick up more electricity, increasing the voltage on the outside coils, making a stronger electromagnet, which gives a higher overall output.
Some of you might notice that this is kind of a circular pattern. And indeed, it would be a runaway effect, were you to short the wires. But because there is a 6v battery, like an empty bucket filling up. The electricity from the generator will pour into the battery instead, making it hang a little higher than 6v (most likely 7v).
If your battery is full, the generator will keep pouring in more, making your battery heat up, and having the voltage in the system go higher and higher, and it might eventually break your light bulbs. So if your battery is often on the full side, make sure to lessen the generator output, to save your electrical system.
