I bought a generator/alternator that worked fine for a while, and then it jumped to 10 amps and did not go back down to zero after the car was running for a while. Any ideas?
Thanks.
Latecomer
Check battery connections and water level. What happens when you turn on the lights? Are you still 6 volts? get a meter reading across battery posts mine reads 6.6 when engine is not running. Good Luck
Thanks.
Latecomer
