mshmodela
Here is the end plate for the 1929 through early 1930 generator with the ball bearing rear end plate. I need to take the same pictures for the bushing end plate. Everything is the same except for the bearing vs. the bushing.
I put too much grease in the bearing and had to remove some. Notice the thin brush is the adjustable brush, and the short side of each brush faces the pivot on the brush holder.
Nice and clean... wow! What did you use to clean the end cap?
