Genarator
30Ford
Are there any good links for Model a generators ...Had mine rebuilt and it does not charge ...I have a feeling that the field coils are backwards Just want to do some reading ..checked this site and did not find what i wanted
thanks
thanks
Did you, or the person that rebuilt it, polarize it?
Charlie Stephens
If you have a voltmeter, with motor running, measure the generator output to ground, if the voltage is positive, try reversing the 2 field coil wires. Then polarize the generator. That should solve you problem.
