1946
I hope you all had a good Christmas. Greetings for the NEW YEAR
I recently decided to repair my gear box top and gear shift lever system. The leaver was waving like a flag in the wind. I dismantled the one in the car, and two others. Two had emergency brake mounts, the third did not. Two levers appear to have had the bottom ball section worn the third did not. The third was the top without a brake mount, I assume this is an early top as it came from a milti plate clutch set up Complete clean and lube and re assemble gave a better shift movement. All pins were replaced with suitable roll pins.
My question is, how much wear should be classed as too much, secondly the top with no brake mount early or late.
Greetings, Rob in Tasmania.
