Gear Replacement, 1933 V8
Al Corbin
I need to replace the rear sliding gear in my '33. Is there any way to remove the 2-piece shaft without removing the engine or the rear axle?
If there is, somebody please tell me quick since I'm getting ready to pull the engine and trans. in my Avatar car to install the later gears in the stock '35 box. I have always pulled either the engine or the rear to do any work inside these transmissions relative to their gears. I'm thinking and betting there is no other way to do it.
Al, on another subject.....do you still repair radios that were used in these early Ford V8's?
Al,
I agree with JM and Mart, no easy way. If your sheet metal and
grill is lined up real nice it might be less frustrating to yank the rear end and
proceed that way.
Charlie ny
There is no way. To remove the 2 piece shaft you have to remove the input shaft from the front of the trans but first drop the cluster which means you have to remove the cluster shaft from the rear of the trans. Of course you have to remove the U-joint to slide the output shaft forward which means you need access to the entire rear of the trans.
