Sounds like your friend is trying to offer you a later model 8" rear end. Is it just the 3'rd member or the axle assy.? Numerically most of the early 50's Fords had 4.11's or somewhere around 3.89's. I do know first hand that nothing numerically 3.55 down will not replace a housing that occupied the 4.11 or 3.89 gears in the 1950 housing. If you are going to retain the 49-56 axle housing you would need to use a 54-56 housing that had 3.55 gears or lower number. Reason being the ring gear hits the rear of the housing when trying to install the later highway gears. You will also find that the axle splines changed somewhere around 54-55. IMO you may be better off looking for a complete 8" from an early Mustang,Maverick or Fairlane. Your housing should measure close to 53" axle flange to flange. Same as 57-59 Ford car or wagon.[/QUOT
Referring to the work you did on my '50 Sid? Still working good! Thank you my friend............
