A '26 Studebaker manual said, "Remove the shift tower & wash it out with GASOLINE"Ford said to drain the gear case, add kerosene and run it a few minutes and drain that, then add new oil.
You gotta' OLD electric hot plate? That'll WORK.
Bill Warm
Put pan under drain plug, open plug, and let drain for at least 24 hours.
David,Bill,
Or just wait until summer when it's over 100 degrees in the San Joaquin Valley. That should do the trick. We'll get that here in the I. E. in a coule of months too.
David Serrano
