Good question.
The carb basically has two "main jets" that put gas out into the air stream and they are in parallel to each other (they act independently of each other). One main jet is of fixed size and puts the same amount of gas out all the time. The other main jet is fed by the variable jet that you call the GAV, so the more you open the GAV, the more gas you put into the air stream from that second main jet..
So imagine you are filling a large tub outside, first with just one hose running. That is the fixed main jet. But if you then start a second hose to run into the tub at the same time, that is your second main jet. And you can control how much water runs though that second hose by only opening the faucet a small amount. That is your GAV.
