The ohm reading should not be a significant value for checking an original gauge. They do not work off of resistance, they are a current pulse device. The senders use points to vary the current duration (pluses) and the current duration heats a coil in the gauge which determines the reading. Very different from modern gauges. Not sure there is an ohms value for the gauges that would show it to be good or bad. One test is to connect a 1.5v battery to the gauge and see what reading (if any) you get. The 12v to the gauges may not have caused any damage if it was not over a long period of time. Again, the gauges and senders work off of current flow, not voltage, so may well be fine.
