Gates Fan belt
abbie
After reading the responses to Evan NPG+ Collant and what a Gates fan belt would do I have been looking for the Gates belt. I can't seem to find any listed in the catalogues I have. Would someone please list the part number for these belts and what distributor might have them. I realize I will need to measure the size I will need. Thank you.
Try NAPA. They carry Gates. There are 3 lengths commonly associated with Ts. 30", 31" & 33 3/4". One of these is Gates number 819 -- maybe the NAPA fellows could start from that & the size you need. I will try to check a couple of cars in the barn & see if the numbers are legible --
The Gates belts work well. I have used serpentine belts on other cars with good success. Again NAPA can match the length & width you need.
Rockauto.com has them and most NAPA stores either have them or can get them. You will be very pleased when you have one. Model T fans tend to be underrated but it's usually a slipping belt problem. If you have an old belt a bit of rosin can make a huge difference. Sometimes spraying some good dish detergent on it and then a good hot water rinse will get the oily residue off and get it clean enough to grip really well.
John: Thank you very much. I will call NAPA in the morning and keep rockauto.com in reserve. Also, like your car; the belt is going on a 23 "T" speedster.
after reading the responses to evan npg+ collant and what a gates fan belt would do i have been looking for the gates belt. I can't seem to find any listed in the catalogues i have. Would someone please list the part number for these belts and what distributor might have them. I realize i will need to measure the size i will need. Thank you.
napa
Just returned from NAPA and they were unable to match a number with Gates 813. I went on line to rockauto.com and they had it and it has been ordered. Let's see what happens from here. Thanks for the help and the info on Rockauto; I will keep that for use again.
the flat gates belts were relisted as commercial belts a couple of years ago.
Some stores have a hard time getting them. Some warehouses have them but don't know it. Maybe they are listed as truck belts but I think it is commercial or industial.
Try industial first.
This is how they were listed last I bought some:
811 was 22 1/2 inches long by 1 1/8 inces wide.
813 26 3/4
814 31 1/2
822 36 inches long and 1 inch wide.
They are no longer listed with the car belts, like you can't go to Ford and look under model T or by any year. At one time they were.
I have also seen some cars with ting belts in-side-out running fans & water pumps on the T.
Just an update on the Gates Fan belt. Lang's no longer has them, NAPA could not match it up with commercial, I have been waiting almost a month for Rockauto to deliver, they had allready charged my card with the order and they told me Thursday they could not get them. I have ordered one from O'Riley's and is suppose to be delivered in seven days. We will see.
sombody has it what number are you looking for
