Growley bear
A few (3?) years ago It was mentioned that installing a Model B cyl. head would be something that I might like.
I installed model b head-camshaft-distributor-already had b intake manifold. Engine bored to .100 OS and a good Zenith carburetor. I liked the extra hill climbing ability and the 3.54 gears seemed more like stock Model A. All was well until I became the proud owner of a couple of very rusty Zenith B1-2 carburetors, one of each. The first order of business was to find out and learn everything that I could about the B carbs. Not much different than the A, but different enough. I also have 3 different charts for comparison.
Now to flow test the jets. I found that the flow charts seemed a little on the lean side, but persisted, especially w/idle jet. I also ended up with a bit larger comp and main jet. This has turned out to be a very wise choice at least for me.
I was puzzled though as to why the jets needed to flow so much more fuel. I think I have the answer.
Not knowing when the charts were made, I can only guess that the gasoline/petrol has been laced with more alcohol there by diluting the BTU count per pound of fuel. I use a 36 inch head of water per Tom Endys' paper on flow testing jets.
Has anyone had similar experiences and maybe some thoughts in this area. I think that this would be helpful information for anyone not too familiar with the process as much patience is required here. I want to express my thanks to the folks who have taken the time to draw up these flow charts as I know it wasn't easy.
The engine purrs along and pulls very strong, so to pass it on, if you have been thinking about a B conversion on an A engine, try it you'll like it.
