PO51 Senior Member Aug 8, 2016 #1 So is the gas tank different on the 1929 fordor and cabriolet? If so I'm in need of one! Last edited: Aug 8, 2016
redmodelt Well-known member Aug 9, 2016 #3 They are standard gas tanks under the cover. So any 28-29 gas tank can replace the fordor and cabriolet tanks. After removing the filler panel on the firewall and removing the clips along the side the tank should come out leaving the cover in place.
