My friend did this with the tank for his 39 Chrysler, used ice for the tumbling media. Worked great....
If I had a rusty tank I'd put some Black Beauty inside and tumble the tank by strapping it to a cement mixer, then rinse it out...
I must be real lucky I just finished cleaning another tank . Not a whole lot of danger in a tank that's been open to the elements for years .a vacuum motor will generate sparks. If you were able to vac out a gas tank you were lucky.
I think flushing a tank numerous times is a safer alternative. Worked for me several times.
Bob
Bob
Seems like this is always an ongoing topic and probably always will be one. Here is a 30-31 Tank we cut open.![]()
I had mine off and took it to a radiator shop. From what I can see it (not much) it looks good. I just have to keep it from Rusting until I get ready to use it. I thought about putting a gallon of diesel in it and tumbling it ever so often.
Its not the gas tank that blows up, it is the vacuum that blows up. Buck Edwards of Bellingham watched a vacuum blow up several years ago. Buck said that the fellow was using his wife's vacuum to clean out the fuel tank debris, when the vacuum blew up from the gasoline fumes. The vacuum went flying across the street into the neighbor's yard. Luckily, no one was hurt. If someone would have been in the vacuum's path, it could have been lethal. When I vacuum out a fuel tank, I use a jet vacuum hooked up to my air compressor's hose. No sparks using the air powered vac.I've never heard of any one blowing up a Model A Gas Tank with a vacuum.![]()
When I saw the hole on the bottom I would have cut the bottom open and sold it to a hot rodder that could install gauges in the face of the tank. There are enough better tank so you don't need to bother with one that rusty. In the meantime I've seen hot rodders cut up very nice tanks to install gauges.![]()
