I believe there is too much of a liability for someone to reproduce these gas tanks mainly because it rests right above our legs. There are some shops that will cut an original open and clean it up and fix/weld any damaged areas and reweld giving you a basically brand new tank. It will run you a decent coin but being a gas tank makes it worth it in my eyes. I plan on having mine done soon.
Hope this helps
Travis
I agree with BashawT. Any company than make gas tanks for model A's would be inviting bigtime lawsuits if any of their tanks were involved in a accident. I also think making gas tanks would be a tough task as they are a fairly complicated assembly and the price for the tanks would probably be quite high. Since there are still original tanks available, the demand would probably be low, at least initially, especially if the "new" tanks were as expensive is I think they would probably be.
Rusty Nelson
Well if what you two say is true, please explain why tanks for Model-Ts are still made ...and so are repro ones for 1932 and up! Also explain why motorcycle tanks are made. Seems like those 3 types alone would be just the same when you explore the dangers!! I don't think it has anything to do with liability!
To the OP, ...restore the tank you have.
well their contention was that the occupant of a Model "A" was sitting next to an atom bomb but as you say, the Model "T" driver would be sitting on top of a similar bomb. Had anyone been injured by spontaneous ignition of the Model "A" tank, we would have heard about it. I would guess that the later tanks are comparatively easier to construct, maybe?
Nobody reproduces the model A gas tanks.
If you go to the archives and look at the prints -and all of the revisions it becomes crystal clear why someone doesn't reproduce Model-A tanks. Just to answer it for yourself, just exactly which one would YOU suggest needs to be reproduced, ...and why??
I think they are just too complicated to make with the market out there, and it has nothing to do with liability. Ever opened one up? Brent had pics a while back showing what he does to restore the tanks.
Even if you could come up with one design for the round and oval speedo, you still have three major categories of tanks 20's, 30's late '31.
A lot of money for jigs and stuff. Just my opinion.
Again, the best way IMHO is to open the tank, remove all of the problems, tighten all of the rivets and weld it back together.
A couple of posts like this one in this thread, mention "welding" as a method of repair for a tank. Les Andrews Manual Vol I has a chapter on the gas tank. The prelude states in part ". . . never attempt to weld a Model a gas tank because they are made from hardened steel and will cause hairline cracks and create more problems. . . "
So, curious to know, has anyone weld repaired a tank successfully?
you said in one post that the terne finish within the tank itself can deteriorate.....how do you address that?The picture of the tank posted above by Afordman is my picture showing the inside of a tank. I think when I was researching tanks at the archives, there was like 7 different versions of a gas tank. The ROI on even manufacturing 2 - 3 different tanks would likely not be there even if a new tank could be sold for $1k.
I guess my answer to 29 Cabriolet comment is we probably don't need to believe everything we read.![]()
If for no other reason, lets consider these two thoughts regarding that comment. First, if the metal was "hardened", how was Ford able to stamp the metal with such a deep draw without cracking or splitting? Second, if welding created hairline cracks, then why is it after 75+ years, you never see cracking in the welded area where the two pieces were joined? Again, just because something seems believable, don't always take it for 'gospel truth'.
As for restoration of a Model-A tank, it is, --and has been done for quite awhile now. Different methods have been used by different shops depending on what their capabilities are. For us, I choose to use the least noticeable way of proper restoration of a tank. That is opening the tank where all internal areas are exposed and can be thoroughly cleaned, and all rivets that attach brackets are repaired. Others will saw holes into the tank's exterior, clean what they can see, then weld patches over the top of the metal which is always noticeable IMHO. Others try to tumble objects inside or use flushing as a way to dislodge rust & debris. From my personal inspection/experiences on tanks that this has been done, it is very incomplete and temporary at best.
Therefore I suppose it boils down to the quality someone is seeking or willing to accept. Bottom line is there are enough Model-A tanks still out there to fill the need for the hobby. The problem as I see it is most people don't have the capability to do the job themselves and have trouble embracing the costs/work associated with tank restoration.
