HDowse
On a dust off ride on Sunday, my tank gauge read empty with a full tank so on return I removed the sending unit and found the float full of gas. I tested the gauge and it works OK. A new float and gasket are on the way from Joe's but I want to be sure I reinstall the sending unit and gasket back on the tank correctly. My question is should I put the gasket on dry or use a sealer like the gas-resistant Seal All? The sealer makes sense but is there a reason to put it on dry? Thanks for your help.
