Short version summary of just one (1) sealed gas tank experiment & one (1) successful experience which was already mentioned a few years back:
1. My Model A was stored for about 30 years with no gas in a formerly sealed tank ...... most probably the "Permatex/Alcohol" sealer recommended in the early 1970's by MAFCA, in "The Restorer", prior to the introduction of ethanol gas.
2. Put ethanol gas in tank, allowed it to sit for several months while rebuilding engine, later drove about 20 miles during my oldest son's wedding whereby engine started missing.
3. Found black tar like substance coating in carburetor & intake manifold, & black flakes with rust when draining tank.
4. Tried soaking tar coated areas with PB Blaster, Kroil, Kerosene, gasoline, acetone, lacquer thinner, carburetor cleaner, rubbing alcohol, all of which was "not" cleaning the carburetor or the intake.
5. Hit the jackpot with a 1:3 mix of POR 15 Marine Clean mixed with (3) parts of about 170 degree tap water -- this warm mix aggressively attacked the hard tar coating & broke it down about as efficiently as a large wild beach cow peeing on a tall beach sand castle.
6. Next, mixed a large batch of POR Marine Clean with hot water, poured it in the tank, sloshed it around, & drained the tank through a cotton sock filter, into a bucket.
7. After seeing the cleaning action, repeated step 6. about (5) times ....... then ordered a $30.00 pump from Amazon & pumped POR 15 mix through the tank for about (3) hours ....... untold amount of debris.
8. Rigged up a hair dryer to a (6) feet long vacuum cleaner hose to dry tank ..... poured about (2) quarts of lubricating oil in tank, filled with water ...... oil stayed on top of water & oiled the tank as oil rose ..... slowly drained tank & allowed oil to oil the metal in the tank as it drained ..... installed an in tank cylindrical filter plus a NAPA 3039 filter in sediment bowl, added (4) ounces of Marvel Mystery oil to gas on every refill & never had a problem since.
(Note: POR 15 Marine Clean will remove petroleum products deep down in the pores of porous metal ... if metal is left clean as such it can quickly acquire rust through oxidation).
Never be against formal education; however, if you ever have to solve a very difficult problem that has not been addressed, just remember that if Thomas Edison would have acquired a formal education, the University jackasses would have explained "why" it was impossible to make a light bulb -- just think ..... everybody has an unused computer between their ears.
Hole this helps Model A guys to try different unheard of things & never give up.
