fred93
I have read several posts that talk about the pros and cons of sealing the Model A's gas tank. I know that some shops will cut open the tanks and media blast the inside and then seal the inside with a liquid sealer. I plan to have a local radiator shop boil the tank to clean the inside (it doesn't look all that bad--but I would like to start with a clean tank as long as it is out of the car anyway). The shop said that they normally seal the inside with a aircraft type of sealer. I thought that this process would be good until I read the posts here about sealers peeling off and plugging up everything. So now I am thinking just to have it cleaned out and forget the sealer.
However, I may have another problem! I looked at the tank today and noticed that there are some stains around the steering column bracket. Are these the start of a fuel leak??? If it is a fuel leak what is the fix??? Also, I am a little concerned that the threads on the fuel filler neck are somewhat worn. I purchased a new cap and it seems to tighten down better than the old one, so maybe the new cap will take care of the problem???? I have been told that the neck on the gas tank can not be replaced like the neck on the radiator (or maybe no one WANTS to be "responsible" for installing a new neck on the gas tank????)
