Gas stick markings
smittykid
I am planning on repairing/replacing my gas gauge in my 30 Coupe. In the mean time I want to make a gas measuring stick. Thanks to C.L. Chauvin I think I have the calibration markings figured out. My question is: What should I use to make the markings on the stick that the gas won't eat? I plan on using a piece of solid oak about an inch square and about 13" long. Thanks, Smitty
Why does it have to be so complicated? A paint stir stick and a sharpie marker is a fancy one. If you're a grown man, take your pocket knife and make a few notches on whatever stick you can find in the yard. Good Luck.:)
I don't want to disconnect any gas lines for fear of potential future leaks. I also want to make sure that the gas level is below a 1/4 of a tank so I can remove the old gauge without leakiing gas into passenger compartment.
Hi Smitty,
We used to carefully make similar fuel measuring sticks for our old tractors years ago.
I recently made two (2) fuel measuring sticks, one to place in the Model A, & one to hang on the wall near the car. Really only use them when very low on gas to estimate how far I can drive when near empty.
They are easier to make with a softer wood such as cypress, poplar, pine, as compared to harder woods; plus, they are really never subject to wear or abuse.
One can provide a rounded point on the bottom of the stick to create less fuel disturbance when inserting the stick in the tank & there will be no sharp corners to rest on the non-flat Model A tank bottom for far more accurate fuel readings.
Make light measured marks first with a knife or sharp pencil, then cut neatly provided 90 degree marks with a (3) corner file, all with equal depths.
Use a No. 2 pencil to mark the numbers in the soft wood, first lightly, second time press harder.
One can also make much simpler roman numerals with a pencil that only requires straight lines for the I's, X's & V's.
Then neatly mark only bottoms of vee cuts with a No. 2 pencil.
I used (3) coats of Formby's rubbed on polyurethane finish; however, mixing any rubbing oil with about 10% polyurethane varnish with render very professional results -- even works wonders as a professional finish on newly made or reshaped gun stocks with or without checkering.
It might take 10 minutes longer to make several measuring sticks like this; but, it will look like a manufactured bought vintage item you can be proud & you won't have to hide it wrapped in newspaper because it looks like an El Cheapo "ugly stick." LOL
If you don't think you can disconnect and reconnect at the carb to drain the tank without screwing up, what makes you think you can successfully R&R the fuel gauge? DRAIN THE TANK or get help from someone with more experience.
I'd also suggest you do a search on fuel gauge gaskets to get the skinny on how to get the job done without leaks or failure. There's prep work you will need to do on the tank sealing surfaces and it is not fun with a partially filled tank in your face.
I just drained the gas from my tank by disconnecting the line from the valve under the dash and connecting a hose from Home Depot to it. I drained it into a gas can using the valve after I connected the hose to it. I used a plastic lawn garbage bag to cover the carpet on the floorboard and put an old towel on top of the garbage bag and a small container in case I dripped some gas (which I did drip a couple of drops because my valve was not holding). I replaced the valve reconnected the fuel line and I am back in business.
Hi Smitty,
Might be helpful to remember that gas fumes being heavier than air will fall downwards with gravity.
So working on even an empty tank, (even with the gas cap & the gas gauge removed,) can still be dangerous enough to proceed with caution..
If one has a gas gauge assembly with proper float weight & proper wire length, one can provide a hook on the end of a clothes hanger wire to gently pull both gas gauge wire & float upwards until it touches the top of the tank.
Then simply adjust the gas gauge wire such that the horizontal lines on both sides of the rotating gauge's "F" are aligned with the (2) horizontal fixed lines behind the gas gauge glass.
Different lengths of gas gauge wires & different types & weights of floats can affect the accuracy of such a floating Model A gas gauge.
After repairing my totally inoperable gas gauge with new parts, I found that the gas gauge after initial adjustment was just as accurate on the 1/4, 1/2 & 3/4 mark as that of the newly made wood measuring stick.
Just hope this helps.
When Your Done Making Your Gas STICK Please Show Us The Pictures Ok
Thank You
Harley03joe :)
Ryan:
You Did GOOD :D
Harley03joe
Look Here
Click here: Ford - Ford Model T Ford Gas Gauge - Wooden Stick - Macs Auto Parts $4.98 :)
