Hi Michael,
Below is a $2.99 stick made by Wm. Harvey for years.
It is sold at local hardware stores, (or order on line), for sealing "gasoline" fittings as well as others.
It can withstand 2,000 psi & 3,500 degrees F.
Unless you intend to attach a 2,300 psi air compressor to your gas tank, or heat your shut off valve cherry red with a torch, this product will work 100% of the time.
I used it for over 60 years with no failure.
Get one (1) stick -- after use, store in a zip lock bag to prevent drying out -- promise it will be the last pipe dope you need to buy for at least 10 years for your Model A & all of the plumbing "honeydo" projects around your house.
Print
Pipe Thread Stick
ITEM 682109 | MODEL #030005-144 by
William H. Harvey
Pipe thread compound in stick form. Lubricates, seals and prevents rust and corrosion. Use pipe stick on pressures to 2,000 PSI, temperatures to 3500F for metal pipe carrying water, steam, air, ammonia, gasoline, natural gas, butane, propane, freon, petroleum oil.
Hope this helps.
