Oilslickwillie
Do you have to drop the gas tank on a 1955 Ford Fairlane to replace the sending unit or can you get to in from inside trunk?
They look like this... approx 3/4 inch by 1 inch..... All the important circuits go through a couple of circuit breakers under the dash ....
1 wire may consist of 3 colors, red, green and then orange from beginning to end of wire.
In your photo, what is the little cylinder with the one wire attached to it.
I see one like it under my hood but it's not attached to anything.
I can't even find a fuse panel on the car. A lot of work to do.
If you do a few minutes of detective work to figure out which parts and what the prev owner did to set up the fuel gauge it will increase your chances of getting the right sender the first time.Macs has one that is suppose to work, it's for 6 or 12 volt and suppose to fit 1955 Ford. 49-20528-2
