nkaminar
Yes, higher compression ratio and taller gearing helps. Higher compression leads to higher efficiency which leads to more miles per gallon.
Depending on where you live and how hilly that is, changing to taller gearing will mean better mileage but it won't pull the hills as well. An overdrive is nice in that you can have the standard gearing for hills and then shove it down into overdrive for the flats and down grade. I use second gear with overdrive a lot in the hilly country here. On the back roads I use second overdrive going down grade to save my brakes.
