Gas leaking from float bowl
john in illinois
I have a 97 that leaks internally from float bowl. It is not evaporating,and with the air horn off I can watch it drop. Fuel level seems correct. I have had different power valves in it,so I do not think it is pv leaking.
Could the accelerator pump check valve be the cause? It pumps ok and the carb idles fine,but has always been hard to tune. I knew it was always low on gas when the rear carb was full,but did not realize it leaked so quickly. New 97 with
1500 miles on it. I do not want to send it off to Max if I can fix it.
John
I found it today. Front power valve was leaking. It was either defective or not tight enough. Replaced it with anew one. Bench tested it and no leakdown.
Ready for a test drive tomorrow.
John
