Gas Gauge
Ray64
My Gauge is off by 1/4 tank .How to get it adjusted> What tools and method is best T I A RAY
Pull the float up with a wire so that the float touches the top of the tank. It should read full at that position. Adjust accordingly by bending the float rod.
If you have a spark screen at the filler cap it needs to be removed in order to do the adjustment.
For What It's Worth: I read in a tech article that Ford set the float rod adjustment so when the gauge reads "E" there was still a gallon of gas left. I've done this and it freaks out my wife who thinks we're going to be walking soon. :)
My gas gauge is set like arnhemmer's, full when the float hits the top. "One of these days" I keep telling myself, I am going to drain the tank to see exactly where M/T is on my gauge... but not today. :rolleyes::rolleyes:
X-2 BUT that doesn’t help if you don’t look at the gauge ! No I haven’t run out of gas in my A, modern’s yes pulling into the station :(
