Gas Gauge
It's adjusted by bending the float wire. A quick test: Reach in the filler with a wire hook & pull up, gently, until the float JUST hits the top of the tank. It should then read"F" (full).
When adjusted properly, you should then have about a gallon left, when it reads "0" (ZERO, NADA, ZILCH!)
Bill W.
