I know I saw it somewhere, but can't seem to put my finger on it. Is there a blow-up view of the gas gauge assembly? I am going to remove the gauge and replace the float and reassemble with new gaskets. I just want to see the correct order of things.
James, Me & the DogI had no problems doing this little job. I think I did look at one of the catalogs to be sure I knew the correct order of things as I put it back together, but it was really simple to figure out as I recall. I don't think you'll have any problems with it.
You can do it with gas in the tank, just low enough that the level is well below the hole in the tank. It's also more pleasant to do in a well ventilated location so you don't smell so many gas fumes.
The cork float is sealed with shellac, which dissolves in the ethanol gas. The cork will absorb the gas and then sink. Neoprene is best.
Tom,I put a cork float in my gauge about 20 years ago. It still works fine even though I've had some tanks of crap gas in it. Any more replacements will be the new material though, just to be safe against a sinking float.
I believe you. I knew a gent about 55 yoa who swallowed two aspirin (the big one, not the 81 mg your doctor prescribed) every day until he had a stroke or maybe a heart attack. Great guy, and we couldn't convince him to stop. we buried him in his mid-fifties.James, Me & the Doglike to get HIGH on the gas fumes. I once heard of an Old Painter, who put 4 drops of Lacquer Thinner in his BLACK COFFEE
And I DON'T make up these WEIRD stories
Bill W.
Hi Gents,
I cant remove the brass inner nut #6 from the housing, any ideas on how to loosen it?
