coupe1942
I put my trim ring into place the other day and I don't really want to remove it again to look over the gas gauge assembly itself. I have some real trouble in reading it at times, as it is just too light on the lettering to satisfy me. I have been thinking of either powder coating it on the numbers or using a gas resistant paint as done on carbs to highlight the level markings on the plate.
Is the plate held in place with a pin that can be pressed out or is it some type of screw? Can this be removed without easily ruining the unit?
Not sure if I will do this or not, but I may try doing it on another unit just to see if it will work okay or not. I am thinking that the numbers and markings are all indented into the metal curved strip, but not for sure.
First two photos just show what it basically looks like now. As said, i have a difficult time easily reading the numbers at times. Third photo addresses the questions I asked about the numbering on the gauge. (Typo in 3rd photo says lettering instead of numbering).
Thanks for any info or tips.
