bavArian
Your speedo drive cap will be marked on the "bump" if you have the standard 3.78 rear end it will be marked 9/34 . The vendors only sell this ratio cap and it is way more likely you have the 9/34 . Order plenty of gaskets you adjust the gear mesh with these and can use up to three sandwiched . Adjust so you have a little slack ,no play is no good .
I'll have to check that the next time I get the car out of it's garage.
You're right, most likely it's the standard gear ratio. It would fit the speed I reached quite well, 50 mph without excessive vibration. It seemed like the engine wanted to go faster but I didn't have enough spark advance left. (but that could've been the first signs of the worn point-lever as well)
The drive (with 1 gasket) has very little to no play at the moment.
But having the drive cap on too tight should cause noise whenever I'm driving, right? The noise is only present if I have the speedo cable screwed in and going faster than approx. 20 to 25 mph. If I screw the speedo cable off I can drive as fast as the car will go without any problems.
On the other hand the added drag from the speedo cable could cause the small gear to slide sideways against the drive housing. If the edges of drive housing and torque tube are not exactly at the same level and there's a small shoulder it could cause such a noise. I'll check that next time!
On the gas gauge..
Be sure and use the very thin brass washers as original. These let the nut slide on the gasket without crinkle or damage
I did use them just like pictured in the small picture that was included.
Maybe it was just my luck.
