You did not specify.If you are talking about 32's.5W ones are twice as wide.Roll up or not they are the same on 5W.33-34 sedans the bottom corners are rounded.Coupes are squared off.
For 33-34 coupes, If you are in doubt also look for two slots in the rear, lower flange for inserting the small rubber pads to align the sliding window.
For 35-36 coupes, look for the slots also. The 35-36 sedan/coupe corners are all rounded.
