<snip>
P.S. anyone want to buy a sh*tload of incandescent bulbs....cheap!
Sounds like it is time for a dimmer switch.They are good, but a friend in his garage went overboard with the LED's overhead, and it hurts your eyes to be in there. I told him 'It's like staring at a welder' and he just laughed. He could have gotten by with half of what he has.
Is there some kind of formula an electrician would go by for what you actually need?
I would say they don't! Motor homes are made to run on generators and the new ones have nothing but LEDs.A good friend installed LED lights in their kitchen which I believe were the tube type. During an outage (we have a lot of those in CA) when his generator was running his wife called him to the kitchen because smoke was coming from several of the lights. They called the local fire department and after resolving the issue they told him some of the LED's can be a problem when using a generator. Evidently on the cheaper stand by generators the sine wave isn't very good and it causes the lights to heat up and smoke then start smoldering, etc. I haven't had a problem personally but am using a Honda generator which has a near perfect sine wave. Only saying this as an issue to consider when using LEDs and a generator and am assuming the FD personnel know what they are talking about!
As part of the move to low energy use (and hence carbon emissions), our Government has been changing over any old incandescent or fluorescent lights for the low energy consumption LED replacement free of charge to the home owner. I agree - for a fraction of the energy, lightis much better. There is the cold bluish light and the warmer more yellow light. We take our pick.
In the workshop, they have proved to be a wonder but I still prefer to work on the car just inside the open roller door where I can see our resident King Parrots, Rosellas, Magpies, Kookaburras etc. It makes working on the car a pleasure.
If you want to save a little money, you can convert your current flo fixtures to LED with a simple rewire of the tombstones and no more ballasts. LED's just need power from one end like a normal light bulb. So, all you have to purchase is the LED tube.
I had 8-4 tube T5 fluorescent fixture in my shop. They were state of the art in shop lighting at the time and were quite good. Several years ago I replaced them with 4-250 watt LED's. HUGE difference but in my case, no power savings. Power consumption is about the same. I had the LED guy come out with samples and I huge 1 of the 250's in the middle of the shop temporarily just to see and the one light lit up the shop better than the 8 T5's.
If a generator is cheap, in all likelihood it has a "modified sine wave" inverter, and a LOT of electronics have trouble with that. LED products are a significant example. There have been many RV fires caused by a small LED nightlight that was used while the RV was using a MSW inverter.A good friend installed LED lights in their kitchen which I believe were the tube type. During an outage (we have a lot of those in CA) when his generator was running his wife called him to the kitchen because smoke was coming from several of the lights. They called the local fire department and after resolving the issue they told him some of the LED's can be a problem when using a generator. Evidently on the cheaper stand by generators the sine wave isn't very good and it causes the lights to heat up and smoke then start smoldering, etc. I haven't had a problem personally but am using a Honda generator which has a near perfect sine wave. Only saying this as an issue to consider when using LEDs and a generator and am assuming the FD personnel know what they are talking about!
Yes as 2935ford posted, the existing lights can be converted to LED with a simple rewire and the ballast can be left in place if you want. Check the 1000 Bulbs web site for great pricing on the LED replacement bulbs.
The LED bulbs that are intended to replace an equivalent incandescent all have electronics in the base to do that conversion.LEDs run on DC, so any that are energized from AC power need a power supply the converts the AC to DC at the proper voltage.
