Garage filled with Model A Parts
JoeVR
New member
Jerseyville
IL
Price
1
I am selling a garage full of old Model A Ford parts. There are way too many to list, but I’ll put out an initial list of what I see.
If you are interested in buying this entire lot of parts, including all the other boxes of misc. Model A parts I have not listed, I can make you a heck of a deal. Just let me know.
2 Model A engines. They are fairly complete (with heads intact) turn over and have compression. I don’t know too much else about them. $260 each
4 Doors. They are not rusty and still appear to have the original wood inside them. $100 each
Complete Rear End with differential, Wishbone suspension and torsion bars, complete drum brake setup as well. It is all together. $300
6 Model A front fenders. 3 complete sets, good for rat rods. 5 fenders are steel $40, and one is fiberglass ($60) The fiberglass one has the spare tire cutout.
3 Model A hoods and sides, $40 each
6 exhaust manifolds -- $35 each
2 Autolite Heaters $25 each
Complete Manifold $40
Rear Engine Mounts $20
2 gas tanks. Light rust inside, but cleanable and usable -- $65 each
Complete Hoods with sides -- $110 each
Carburetors – unknown condition -- $20 each
Complete Model A exhaust NOS ($110)
Complete Model A exhaust, lightly used ($50)
Glass fuel filter units -- $10 each
Glass replacement bowls – $5 each
Several Bellhousings -- $40 each (some have inspection plates)
Shifters with forks $35 each
7 starter motors in various states of disassembly ($10 each)
8 generators ($20 each)
Old Headlight buckets, steel ($10 set)
Aimable Spotlight on an arm ($20)
Several steering columns – some complete, some partial. $40 without gearbox, $70 with gearbox
Engine block, has a cam in it, but other than that it is bare. $25
Flywheels $50 each
Rear axles -- $50 a pair
Rear torsion bars - $25 apiece or $40 for the pair
clutch housing (it mounts on the block ) -- $50 each
Drum brake assembly – including backing plates and drum setups - $25 each
Valves $4 each
Steering gearbox only ($25)
Water Necks -- $20 each
Original Wooden seat frames $10 per
Spring seat frames -- $10 and $5
Boxes of bearings, bulbs, brakes, clutches, pedals, transmission gears, etc.
Axle tubes – right and left side $50 for the pair
Differential gear with bearings -- $45
License plate bracket $15 each
Brake swivel piece (it is hard to describe, but it connects the pedal with the brake rods. ($50)
Pickup under-bed filler piece ($40)
Oil Pan -- $20
Luggage Rack (mounts on bumper) - $25
License plate bracket with light -- $15
Piston Rods $5 each
Radiator Fans - $10 each
Window regulators.
Original door handles, window cranks,
Engine Pulleys
There are SO MANY other parts that I have not listed, here. I would prefer to sell everything as a lot to the right person. I could even deliver within a reasonable distance for the right price.
Located near Jerseyville, IL
ZIP code 62052.
Joe 309-212-644 one
Everything is being stored in my garage.
Re: Garage filled with Model A Parts ($1500 obo for all)
Hi everybody,
I have received so many calls in the last few hours, that I have changed my mind and would like to sell these parts as a great big lot. As much as I would like to help people out with their Model A projects, it is going to take me too much time to try and field everyone's calls for individual parts.
I will take $1500 or best offer for this entire lot of parts. There are thousands of dollars of parts, here. Come to my garage with a trailer and haul them all home.
I forgot to add that I have . . .
four un-rusted doors
several door handles, window cranks,
lots of little interior trim pieces,
Lots of brake rod things . . .
accelerator/spark advance rod things.
inner tubes,
Lots of other sheet metal pieces that I can't identify.
more window regulators
more carburetors
some tin filled labeled "steering column parts" filled with small pieces, seals, and springs
a few pedals
So many other parts. I still have not listed them all. I'm really not sure what they all are, but I know that they are Model A parts.
Also, to answer a commonly asked question . . . the steel fenders do have cracks in them on the outside. Two of them have been welded a long time ago. The fiberglass one obviously does not have cracks in it.
If you live within a reasonable distance, I have a retired friend in a local car club who can deliver these parts for a fee.
I just want to see these Model A parts going to someone who can use them.
Please email me or call and I would be happy to work this out with you.
Joe
I recently sold from this lot:
1 windshield visor
1 starter motor
4 wishbone suspension links.
The rest is still here.
-Joe
