M melisa Member Nov 9, 2016 #1 have 62 ford galaxie, 9" rear, need part # of part that u joint attaches to. Hope someone can help. Tks Melisa Last edited: Nov 9, 2016
Robz51 Senior Member Nov 9, 2016 #2 Try googling "9in Ford pinion yoke". There are different sizes for car/truck etc, but it may steer you in the right direction. Rob
fordor41 Well-known member Nov 9, 2016 #3 any drive line shop can probably fix you up with one. May be the same as a pick-up.
Ole Don Well-known member Nov 16, 2016 #4 Speedway Motors lists yokes for that. Measure the old one for U joint size and length.
