Fyi
jackball
Have a 31 pickup. Started to run hotter than it normaly does. Found that the problem was a restricted after market fuel filter, causing the engine to run lean.
Hope this help some one along the way.
Jack
Good tip Jackball. Many of the aftermarket automotive fuel filters are designed for pressurized fuel systems. If you decide to add an inline fuel filter to your Model A be sure that it will allow gas to flow freely.
