larry harding
i finally found a useable(needs a little work) frame for my project. now for other challenges...
1. i want to reverse the spring eyes to lower the stance of the car. i've heard about taking the main spring and working it straight and then curving it the other way. seems like a lot of work. can't the spring be heated and the eye bent the other way the quench in oil to re temper? i've done that on other various springs with good luck. several years ago i had a spring shop shorten the leaf spring on a project i was working on. i think they used a rosebud to heat the spring end, rolled a new eye the quinched it.
2. you tube videos of speedsters show what looks like a "t" gas tank sitting up on edge rather than laying flat. don't know if they are using a special tank or making one with the filler in the edge. i think i can fabricate a tank if i can find the neet brass fill er neck and cap. any suggestions?
