Fuses
Flyboy1st
I have been looking at the wiring diagram for my 1929 coupe. I think I would like to isolate the different components with fuses so if a tail light shorts out it will not burn out the 30amp fuse I have mounted on top of the starter. Anyone tried this out with success? What kind of fuse used, inline or the new u shaped ones, and where was the best place to locate them.
There are a couple of threads on the subject that, of course, I can't find right now.
Anyway, yes I have a fuse panel that is mounted on the inside of the firewall behind the junction box, hidden out of view. I use the blade type fuses. One of the reasons I like this panel is because if a fuse blows a small LED lights next to it so I can see which one blew.
I also have a 20amp circuit breaker of my headlights.
Be sure to fuse you brake light circuit. That one is messy to fix on the road. Right under the middle of the car.
Y-Blockhead,
Nice orderly install. Impressive!
Good Day!
Flyboy1st, your 30a fuse reference caught my eye. I would suggest caution with using fuses rated above the current rating of the wire it is supposed to protect. I just spent a couple of hours today fixing my (new to me) '30 coupe. Previous owner had 30a fuse installed and when there was a short in a headlamp conduit connector, it burned the supply wire, connector, and pigtail inside the housing before blowing the fuse. I haven't seen any wiring on my car that should have more than a 20a fuse. Cheers
