Depends on the load(s).For the ones about to type a reply saying 10 amps is enough fuse if using all LED lights, NO it's not. What if the motor is running 3 (amps on the coil), the lights are on, and you ahooga the horn?
The horn power comes right off the cutout, doesn't go through the fuse unless the engine is off.
Can't the same be said for the lights?
You also have to consider branch circuits with the wire size. The entire electrical system will get a larger fuse, than say a fuse that's just running your signal lights, with a smaller gauge wire.
You can also buy circuit breakers that will fit in place of the fuse. They will reset when they cool down and you won't be stranded in the dark.
The fuse is chosen to adequately protect the lightest wires from catching fire, right???
Yes. And to expand upon what others have said, most Model A wiring harnesses are made from 14 ga. wire. In my location, code dictates that 14 ga. wire will handle up to 15 amps safely (at room temperature or <140 degrees F).
Current is a rating that includes a time constant. So, let's say a headlight bucket connector shorted and because the wire is 14 ga. the wire conductor would not fail until current reached (lets say) over 50 amps. However, even if the current was only 30 amps, the wire would get hotter and hotter, and with enough time, could become hot enough to burn the insulation and start a fire. Then there is wire length to consider, but let's stick to shorter lengths, like those found in a Model A wiring harness. Then, we could go on and on talking about branch circuits, like the Model A.
So, generally speaking, yes. Fuse size is chosen based on protecting the wire.
Everyone is correct that there is a maximum amount of current that a wire can carry. And that depends on whether the wire is sitting in air or buried in a conduit or otherwise has restricted air circulation. It also depends on the kind of insulation that the wire has. A 6 volt system will, in general, carry twice as much current for a given wattage than a 12 volt system. But a short to ground has the potential to carry whatever the battery will supply, something like 200 amps. In my car there is a 30 amp main fuse and then individual fuses for branch circuits. For instance, the fuse for the electronic tachometer is only 1 amp. The rest of the branch fuses are sized to protect the devices that are connected to them but not more than what the wires will carry.
For a house, this is correct. Automotive applications don’t have a “code”.
