TomInCologne
Hi guys,
situation: i have an alternator (powermaster, up to 60A) and a fuse on the top of my starter switch, Optima battery
I had the situation lately that one of my high-beam lights had a short and as soon as i put the high beam on, the fuse blew. I can't remember wether the engine was running or not. With the fuse blown, i had a look at my ampmeter and it was 'at the stops' so either charging or discharging the battery with mind-blowing current.
So, i had a look at the well known wiring diagram, see below. The fuse is between the starter switch and the junction box, if i understand everything correctly.
So, once the fuse blows and the engine is on, the system gets powered with up to 60A and n fuse will secure the wiring? That sounds like something to improve...
