Fuse for 900 Signal Stat
Brian SATX
Instructions only say have a fuse. What rating are most of you using. It is wired to the starter strait to the control head.
What’s your load, amperage draw ? With the 4 ways on and your engine off look at your ammeter ! That will give you an idea of the size of fuse you need, if the draw is I’am guessing say 10 amps go the next high fuse ! Usually I would ask what is the wire size because a fuse protects the wires .
