Jwawhite
Smelled fuel after fill up, removed inspection lid (which is below the spare tire of a station wagon). This leak is very apparent in the cab and it must stop!
The lid is leaking fuel and I've ordered a new cork 6 point gasket.
Question: Which is the best way to install it? Dry, with cleaned surfaces? Use a fuel resistant glue with the cork gasket? Adhesive only with gobs over the screw heads?
What is the proper way in your experience to have a non leaking sending unit?
